Home > Technical > Got a whining noise :(
Welderman
2009 Range Rover Sport TDV8 HSE Java Black
Just got back from the motorcycle live show and noticed on the way there a slight whine coming from the car.
If I slip it into neutral it's still there so wondering wether it's a wheel bearing or one of the diff's.
It got progressively louder on the way home too. Getting worried now. Can't do anything until tomorrow.
Any obvious things to look for.
Help Sad Newbie near Chorley.
TDV8
Post #444044 Sun Nov 30 2014 10:38pm
DavidHirst
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Did you have your wife with you Whistle MY 09TDV8
Post #444046 Sun Nov 30 2014 10:47pm
Welderman
Unfortunately no Sad Newbie near Chorley.
TDV8
Post #444052 Mon Dec 01 2014 12:05am
Welderman
had the car up on the ramps, looks like the dynamic response piston has a leak and the bad bad news is I think its the transfer box that whinning Sad Newbie near Chorley.
TDV8
Post #444102 Mon Dec 01 2014 5:15pm
ian-r
change the oil and turn the radio up Mr. Green Thumbs Up
Post #444183 Tue Dec 02 2014 8:46pm
Paddi
Is the ARC bar actuator actually dripping fluid or is it just moist where the bar exits the actuator? Moist is normal; dripping is time for a new unit and they are Censored ing expensive.
Can't help with the transfer box but our resident expert from North of the border recently commented that failure to change the oil at the correct interval can cause bearing failure (and presumably a leak here could cause the same).
Good luck with getting it sorted. 2008 MY Java Black TDV8 HSE
Post #444192 Tue Dec 02 2014 9:49pm
Welderman
The arc is just residual oil leak. Probably swaps out thank god.
Had a good chat to an expert and looks like it's the rear bearing from the transfer box to rear prop. So need to undo the prop from the box and see if it's that. If it is then you can get a bearing kit from Landrover. If it's not that it's hands in deep pocket time Sad. Newbie near Chorley.
TDV8
Post #444201 Tue Dec 02 2014 10:51pm
Welderman
Got to the route of the noise.
Rear bearing on output shaft to rear prop. Smashed. Luckily the fragments were stuck to the magnet.
Quite chuffed realy. Saved myself a few bob doing it myself Smile Newbie near Chorley.
TDV8
Post #445176 Fri Dec 12 2014 10:22pm
Welderman
Few pictures Newbie near Chorley.
TDV8
Post #445177 Fri Dec 12 2014 10:26pm
Welderman
TDV8
Post #445178 Fri Dec 12 2014 10:26pm
Chris day
Well done that man Thumbs Up
Post #445185 Fri Dec 12 2014 11:37pm
gogsy1956
good result Thumbs Up 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #445187 Sat Dec 13 2014 12:02am
Welderman
Very happy. And it so quiet again. Until I put me foot down Smile Newbie near Chorley.
TDV8
Post #445188 Sat Dec 13 2014 12:28am
