![]() | Home > General > Ctek help please |
Can't help you with the wiring from direct experience but if you search the site including Disco 3 sister site there are some good guides. However can see that you'd have to remove the cover every time for access. For simplicity its hard to beat just using croc clips onto the battery terminals; or for a slightly more convenient connection you could use the 'comfort connector' accessory. The latter connects permanently to the batt terminals providing a weatherproof plug to use for connecting. 2008 MY Java Black TDV8 HSE
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Can you clarify?
As far as I can work out, this charger works through the White socket or power supply to caravan socket and not tow electrics. Not sure how it works as most sockets are protected by a relay that only energises when it detects alternator is charging. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Yes, it works through the white socket(12s).
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5643 ![]() ![]() |
I have a ctek with 13 pin adapter and think it's excellent |
