Home > Faults & Fixes > New Crankshaft RRS 2008 2.7tdi
Nhlboy44
United Kingdom 2008 Range Rover Sport TDV6 HSE Bali Blue
Hi All
I'm a new member and need some advice. I have a rrs 2.7.tdv6 and have noticed a low tone knocking noise while engine ticking over.the car has done 68 k and was due for a service so I took it a local rr garage,not a Land Rover dealership, and called to say they had taken the timing belt off as they thought the noise was coming from that area.they then called to say there is to much play in the crank
There should be .5 mm but I mine can be moved by hand 2mm and that's what they think the problem is.they said the crank cannot be replaced and that I need a replacement engine 😟😟 the noise is a low drone type noise.
Help please
Post #443940 Sat Nov 29 2014 7:50am
simple1
End float? That's crank moving back and forth front to back. If the crank moves up and down by 2 mm it and sump would be on floor. Sounds like thrust bearing failure, usually associated with starting a car with clutch pressed so if an auto impossible. Am sure it's possible to refurbish the crank and for oversized bearings to be fitted but probably not cost affective. It does sound like oil supply failing so factor in new oil pump to price. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #443971 Sat Nov 29 2014 6:45pm
SRE
Spain
If the car has a full main dealer service history, then it may be worth dropping Pete at Customer services a pm. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #443972 Sat Nov 29 2014 6:50pm
Nhlboy44
Thanks for the info
It is an auto so not sure if there is a bearing there to replace?
Who is Pete and how do I PM him?
Post #443974 Sat Nov 29 2014 6:56pm
You will need at lease 5+ posts to be able to use the pm system.
Here are Pete's details.
http://www.rrsport.co.uk/forum/member-liam-landrover.html
Post #443975 Sat Nov 29 2014 7:16pm
Nhlboy44
The garage I went to said approx£5/7 K to replace engine? Seems drastic as might only be crank ?
Post #443991 Sun Nov 30 2014 8:24am
Nhlboy44
Just checked service book and has 3 main dealer stamps and 3 from Ongar garage which is a Land Rover garage but not a main dealer.
Post #443992 Sun Nov 30 2014 8:27am
SRE
Spain
http://www.ebay.co.uk/itm/Genuine-Land-Rov...1c49f69092 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #444007 Sun Nov 30 2014 2:34pm
Disco_Mikey
£1450 Shocked
I have 2 broken engines that are about to be stripped for spare parts if that's how much they are worth Shocked
Post #444015 Sun Nov 30 2014 5:18pm
