![]() | Home > General > Mirrors driving me mad!!!! |
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 ![]() ![]() ![]() |
i have the same problem but no solution, ill be keeping a eye on this |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
Turn the dip in reverse off in settings
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
its somthing to do with lazy entry sparky, had this problem on mine think i turned lazy entry off in settings |
It sounds like the mirrors haven't been set correctly in memory. Try resetting them again. Don't forget you must use the same key. 2x TDV6. SE and HSE. Both returned to sender with issues👀
