Home > Technical > Aaaargh - flat battery
Mail Order Ride
Hi
2009 TDV8 here, and going well too until today Sad
Its barely been used for the last month and certainly hasnt had a long run in that time
Ive just been out and inadvertently left the key powered up in the ignition whilst the doors are open for a couple of hours
The battery is now dead - it has enough to power the dash and lights but not start it
Questions as follows:
1) Would you advise jumping it from a Mini battery?
2) Wold one of those Halfords battery pack things be OK?
3) Is my battery likely to be OK long term, Im feeling more stupid than worried it may have had it?
Cheers all
Post #443594 Tue Nov 25 2014 11:28am
Bodsy
Site Sponsor
If you mean starting from a Mini battery (i.e. a small battery, not quite fully grown Wink ) I would say you may have problems. However, if starting from a Mini (the car) then you will be fine, but allow the mini to run for a while with 2,000 rpm to help charge the LR battery before starting. Then when started, you need to go for a good run to charge it up. it takes about 8-10 hours for a battery to be 98% charged in your RRS.
Get yourself a decent battery charger Thumbs Up
Halfords battery pack would probably be OK, IF you've remembered to keep it charged up.
As long as it's not left discharged for a long period of time, your battery should be fine. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #443600 Tue Nov 25 2014 12:36pm
Mail Order Ride
thanks Bodsy
It started on first kick from the Mini
As luck would have it I have a 3h trip planned for tonight
Post #443602 Tue Nov 25 2014 1:02pm
Techstyles
Belgium 2005 Range Rover Sport TDV6 HSE Maya Gold
It's ben -4 each morning lately, no idea how cold it gets at night but woke up this morning and there is snow everywhere. I don't drive very much so the battery does need a charge but anyways...
So lights on the dash come in, I waited a little but the car won't start. Get a strange electric buzz in the car, interior lights buzz when I turn the ignition but the engine is dead so I'm assuming it's the battery.
Any ideas? Should I just jump start it and it take it for a spin in the snow?
Post #449558 Sat Jan 24 2015 9:53am
Paddi
Jump starting and driving around a bit won't charge the battery sufficiently to avoid non starts on subsequent days.
If it has been very cold and the battery is so low on charge there is a possibility it is frozen.
The best thing you can do to prolong life of the battery is remove it from the vehicle and put it in place where the temperature is above freezing (like a garage) and allow it a few hours to thaw. Then fully charge it using a smart charger. You could use an unregulated charger but take care not to overcharge and cause more damage. 2008 MY Java Black TDV8 HSE
Post #449569 Sat Jan 24 2015 11:10am
Robbie
Location: Waiting for my old avatar to be allowed back... we miss her!
I agree that it can only be recovered with a good charge with a proper charger but it will not have frozen in the current UK temps. There is no need in normal circumstances to remove the battery and you can happily charge the battery with it still connected to the vehicle. Driving around to 'charge' a battery does almost nothing.
Thumbs Up Land Rover - Turning Drivers into Mechanics Since 1948
How To - Battery & Quiescent Current Drain Testing
Free Fault Code Reading For Established Members:
Defender, FL2, D3, D4, Evoque, RRS & FFRR
Post #449571 Sat Jan 24 2015 11:15am
Techstyles
Thanks guys,
I forgot we had a charger, so dusted it off and hooked it up to the mains, just going to leave it for a couple of hours now.
I have a sneaky feeling my sister left my rear seat heating on and that's been draining my battery a bit.
Sun is back out and the snow is already melting here.
Post #449576 Sat Jan 24 2015 12:14pm
Robbie
It will need 10 hours or more, so best to leave it on charge overnight.
The seat heaters go off with the ignition so it won't be that.
Post #449580 Sat Jan 24 2015 12:35pm
Techstyles
Cool thanks for the help fellas
Post #449583 Sat Jan 24 2015 1:01pm
