![]() | Home > General > Money Money and more money |
loneranger Member Since: 22 Nov 2013 Location: newport south wales Posts: 12 ![]() ![]() ![]() |
sounds like a horror story , Ownership of a rrp can really test your wallet |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
In a year, on a 50k mile car, I have been into ARB bushes, a suspension pump, an aircon radiator, back brakes, a front diff and a gearbox flush. Still needs cam belts, a prop and probably a battery and brake light switch. Oh, and the heated rear window fixing. That is before anything else breaks. Which it will.
Somerset Bumpkin Member Since: 12 Dec 2012 Location: Swindon Posts: 74 ![]() ![]() |
Mine is 5 years old wth 53000miles and I haven't had to spend a penny in anything other than consumables, and even then that's only been one set of discs and pads. The problem with. Using second hand is the previous driver I find, you just don't know how they've abused it. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9133 ![]() ![]() ![]() |
I'm of the opinion that where it's serviced has a lot to do with reliability too. For example, I have just discovered that mine is using some coolant since the last time it was in the dealership (for a replacement turbo). Yesterday I noticed, whilst checking/topping up the coolant, that the coolant hoses to the and from the FBH aren't clipped. The hoses are on but the clips are a couple of inches along the pipe and so aren't doing anything. There is some spray evidence around the area that this is where the coolant is leaking.
Absolutely, a good mechanic noticing a few minor things at service thus stopping them becoming major issues later on can make all the difference. Not a big fan of dealers services myself, got a great independent locally who takes a lot of care over his cars. |
Mark1505 Member Since: 01 Oct 2014 Location: Wales Home, Singapore work & Also many other parts of the world, Posts: 57 ![]() ![]() ![]() |
It would seem the dealer I bought the car from had cheap Ebay discs and pads fitted which i contributed too, I was informed these were original, alas it's now having new L/R Brembo spec discs and pads fitted in my indi, As a case is now in the making with the original dealer in Derby I can not Name and Shame, however if your looking for a RRS then there is a dealer on Ascot drive derby which has many RRS and a number of other prestige cars on the forcourt which you may want to avoid.
