![]() | Home > Maintenance & Modifications > FBH fuel pump |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
there might be more help on Disco3 as they are more hands on and might have fixed similar
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Thanks Nick, no I thought it had locked out because of low fuel in the tank but it was full when tested so locked out because fuel wasn't being pumped up to it... |
Try this thread
Flack you are a gentleman, thanks for taking the time to post the link, this makes it all clear. So first check is to blow the fuel lines clear and if still no joy then a new pump. |
The car has been repaired and it was indeed the fuel pump that supplies the FBH that had seized up, so a new one has been fitted all working well now.. |
