![]() | Home > Wheels & Tyres > 18" rims? |
Badgermo Member Since: 02 Nov 2014 Location: Suffolk Posts: 8 ![]() ![]() ![]() |
I am considering changing the wheels on my 59 3.0 hse rrs to 18" rims with grabber a/t tyres. I tow a 7m caravan quite often. any pros and cons and advice on widths would be very helpful.
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 ![]() ![]() ![]() |
If it were possible to get 18s to fit it would certainly be a smooth ride . |
Thanks Guys.
Just in case anyone is interested;
crammy Member Since: 21 Aug 2014 Location: essex Posts: 167 ![]() ![]() ![]() |
I think at a rough guess 1035 lbs is about 480kg. Not got a calculator to hand but that near enough |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9153 ![]() ![]() ![]() |
Those rims will not survive the weight of a RRS if they're rated at only 1035lb. You need about 2000lb.
JamesRoberts Member Since: 02 Oct 2014 Location: Hampshire Posts: 116 ![]() ![]() ![]() |
I have 18s on mine. Here's some originals for sale on eBay the same.
Just a quick update.
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
What's the load rating of the wheels? 2014 L405 SDV8 RR Autobiography |
1025kg |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 256 ![]() ![]() |
Badger, is that tyre size correct? Have you got a side view photo of your car? I've been given some FFRR 5-spoke 18's which touch the calipers! How much did you have to grind off? |
Hi Salisburylander
I only asked because I've not seen them in 175/55-18 before and that size isn't listed on GG's website! |
Hi Salisburylander
