Home > Faults & Fixes > Transfer Case ECU Location
L4FLIROP
United States 2009 Range Rover Sport Supercharged Java Black
I think I have water ingress in the Transfer case ECU - I am having issue locating it.
Any pointers would be appreciated
Post #442478 Thu Nov 13 2014 5:55pm
It's with the ECU in a box (the "E Box") on the firewall behind the battery. 2012 SDV6 - it's missing a couple of cylinders
Post #442489 Thu Nov 13 2014 7:16pm
L4FLIROP
What is involved to get at it ?
Remove battery ?do I need to remove the Lower Windshield cowl ?
Post #442508 Thu Nov 13 2014 10:09pm
Remove the battery and you should see the e-box. Remove the cover by releasing the clip on each side.
Why do you think you have water ingress in to the control box? What symptoms are you experiencing? 2012 SDV6 - it's missing a couple of cylinders
Post #442511 Thu Nov 13 2014 10:29pm
L4FLIROP
I have been having the HDC fault changed the brake switch but also I recently power washed the engine and I have the LR Christmas tree on the Dash so that's got to be the problem
Post #442514 Thu Nov 13 2014 11:24pm
L4FLIROP
Well this really blows I cleaned contacts found some corrosion and used dioxit on the contacts after moving the corrosion. Reassembled ran my Nanocomm to clear the ECU's and now I have a Permanent ECU Failure on the Transfer case.
Any suggestions ?
Post #442522 Fri Nov 14 2014 12:16am
L4FLIROP
I think the ECU is Toast, I checked the fuses and the Nanocomm is unable to read the ECU info. I am wondering if an ECU will fix this or if there is other damage to the system
Post #442534 Fri Nov 14 2014 2:55am
Paddi
Maybe take the ECU out again, check for bent pins and displaced terminals on the connectors and then reseat all the connectors and try it again. If still no go then there are specialists who can fix the ECU in the UK bba-reman are often recommended but maybe you have local repairers? Good luck! 2008 MY Java Black TDV8 HSE
Post #442627 Sat Nov 15 2014 11:09am
Nickr6r
England 2005 Range Rover Sport TDV6 SE Rimini Red
I had the same hdc fault was the transfer case ecu water corroded the connections
Post #445200 Sat Dec 13 2014 11:26am
