![]() | Home > Technical > Rear disc jammed on..... |
Did you back off the adjuster on the handbrake shoes far as possible? As I recall it is annoyingly fiddly as you can only access it through a little hole and have to push the knurled wheel round with a small screwdriver. If you are having difficulty turning the disc you can use a big socket on the hub but with a breaker bar. Sometimes bashing the disc with a lump hammer might shake the shoes free if they stuck in the 'on position'. Good luck! 2008 MY Java Black TDV8 HSE
scottytd5 Member Since: 08 Nov 2014 Location: scotland Posts: 3 ![]() |
Adjusted the wee wheel (counting the turns) 8 up, as the wheel is at the top, then went back to its original position, then went 4 or so down the way, 12 clicks in total and tried taking the disc of..... no luck, then went fully 12 up again no difference (not sure what way is to free it off its getting confusing for us lol)
Yes know the problem re trying to work out which way is to 'off'. The wee wheel is on the end of a sort of bolt that screws in to the little casting that is fixed to the backplate so you need to peer through the wee hole and work out where the casting is and screw the bolt in to it. Then if you can just keep puling and pushing the disk it will eventually come off. Have a few beers and try again in the morning maybe? 2008 MY Java Black TDV8 HSE
You need to back off the wheel all the way to the loose side. You know if you've gone the wrong way as you won't be able to move the hub. Bodsys Brake Bible
Gents thanks for the replies, after a rest and a few brews wound the wheel till there was no thread showing and with a bit more brute force and ignorance and some real wiggling it's popped off...... Bloody Range Rovers and EPB LOL
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4515 ![]() ![]() ![]() |
You may have to put the EPB into "Mount" mode with a diagnostic machine, if the cable has been extended too far.
