Home > Orders (L494) > Remote Park Heat |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
As i have said before, I paid £165 including postage for the Receiver and antenna, From Landrover Yeovil Somerset, And a remote blipper off Ebay for £20. Then it cost £50 for Indie to activate softwareThe reciever and antenna are plug and play,as plug is already behind O/S panel in boot and a bracket ready to clip reciever into. This being on a MY10 Could be same wireing Loom on new model itisme |
Mon Oct 27 2014 10:02am |
Andrew2706 Member Since: 05 May 2013 Location: Stowmarket Posts: 34 |
tried out the timed climate and worked very well, but have not managed to get this to work via the remote, even standing by the car at 4 degree C. The dealer has checked the car and remote and insists the remote will only work at about 5 degree C or less. Now waiting to see if it will work at 0 degree or less before I challenge the dealer again..... |
Tue Nov 04 2014 6:47pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
IMHO the whole point of the remote is that you can start it when you want it regardless of the temperature. I have used the remote function on mine (not L494) at about 10 degrees and it worked. In fact, since it is not just about heating, I have used it at 28 degrees too and it ventilated the car ready for me. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Tue Nov 04 2014 6:54pm |
Correct, It is a multifunction system, It defrosts windscreen and warms car,warms engine water,so starts easyier. In warm weather it will just operate the fan and cool the cabin. And will not start the FBH. Muddy wheels i have just noticed you said the FBH was O/S behind Headlamp,it is N/S forewards to Battery and Fuse box. Yes the exhaust from it runs down near front N/S wheel arch. You can hear it running before starting the engine itisme |
Wed Nov 05 2014 10:19am |
Just to confirm for 2010 models onwards (not including the RRS2 as I'm unsure the strategy that uses), when using the remote, the FBH will cut in at less than 15C. If 15C or greater, then it will put the fans on to get the hot air circulating, it will NOT run the aircon!
Wed Nov 05 2014 10:56am |
Andrew as Bodsy has just posted it should work at 15C , Has your car got the Reciever and aerial fitted. Some people buy the remote thinking it will work the FBH,it needs these parts to work.It also needs the software to be activated .The remote should work upto 1000 metres distants.What year is your RRS? itisme |
Thu Nov 06 2014 9:19am |
Thanks Harry, its this years model, and I had to pay £1000 for the park heat. I have now found the section in the manual that states "Illuminates green and quickly flashes red to indicate there is no communication with the receiver" My dealer initially said "They had checked the receiver, and I needed to wait for a lower temperature for it to activate" With 1 degree C showing this morning and still no joy, its off to the dealer AGAIN at the weekend..... |
Thu Nov 06 2014 7:43pm |
well here's the update....after 4 trips to the dealer the remote park heat fob will now "talk to the receiver" and activate the RPH but only from about 8 feet from the car. But NOT from my house to the drive, even leaning out of the front door which is about 15 feet away to my car in the drive. The dealer has returned the car and said "They will do a bit more investigating with JLR" Can anyone quote on how far away their remote park heat fob works on a MY14 RRS. Thanks |
Tue Dec 02 2014 8:14pm |
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 |
Funny, he last few mornings when I've started it, I've been keeping an eye close to the front wheel where I was used to seeing the exhaust from the FBH on my 2010 firing up.
Tue Dec 02 2014 8:24pm |
Mine is the old model, not MY14 I know but it shouldn't be too different (if at all). It has a range of at least 80m. Did they tell you where's the antenna located? I affixed mine in the boot, to the offside D pillar, as close to the top as I easily could, behind the pillar trim. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
Tue Dec 02 2014 8:52pm |
Not according to peanutbob above : Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
Tue Dec 02 2014 8:55pm |
Disco Member Since: 15 Nov 2013 Location: Telford Posts: 178 |
No it does not.
Tue Dec 02 2014 9:01pm |
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 |
Mine is also the old shape Rrs and I can use the remote from my office building to the car which is over 125m away with no issues. My one was factory fitted as standard (autobiography).
Tue Dec 02 2014 9:20pm |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
Mine is a 2012 and the remote works as I am coming up the 18th fairway which must be 150-170 yds from the car MY16 AUTOBIOGRAPHY Indus silver with some toys
Wed Dec 03 2014 12:12am |
