Home > Maintenance & Modifications > Lights
ljw350
Lights
Hi, got a 2007 RRS TDV8. The head lights don't seem very bright. Is this normal for RRS?
Post #441482 Tue Nov 04 2014 6:38pm
If the bulbs are originals then they will be dimmer than you'd think they should be. I found replacing the halogen fill in bulb with a new one made a difference. My xenon and halogen bulbs are now all higher output versions. Just put some of these in:
http://www.advancedfactors.co.uk/66240xnb-...3821-p.asp
and been happy with them so far. My xenons were starting to get tired - there is a definite bloom on the old bulbs. My halogens are Osram nightbreaker H7 and they made a noticeable difference when they went in a couple of yeas ago.
Oh, and check that your headlight washers are working properly. Grime on the headlight covers makes a huge difference even if it looks fairly innocuous. 2012 SDV6 - it's missing a couple of cylinders
Post #441493 Tue Nov 04 2014 9:18pm
Leeser23
United Kingdom 2007 Range Rover Sport TDV8 HSE Siberian Silver
Haven't been that impressed with mine since I got her, am sure my disco3 lights where brighter.
Might have to check out those thanks RRSTDV8 2007 HSE V8, steps fitted, interior & reversing LED's, Black badges
Post #441520 Tue Nov 04 2014 11:09pm
ljw350
thanks, i'll check how clean the lights are first. I have the clear protective plastic on the lights as well as bumbers ETC since new (can't remember the correct name) i might remove this from the lights to see if it helps
Post #441722 Thu Nov 06 2014 2:50pm
