![]() | Home > Maintenance & Modifications > Anyone took their cats off tdv8 sport |
| ilard Member Since: 20 Aug 2010 Location: London Posts: 975
Just be aware that removal of catalytic converters or diesel particulate filters will fail your car at next MOT! |
| Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 |
an mot tester can not remove anything from the car to inspect it, if theres a piece of carpet screwed to the bottom of the car and he cant see if the cats are there or not then it can not fail |
If there is a piece of carpet |
| oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359
Pay them to remove your DPF, then pay much more to buy it back and re-fit it. Doesn't make sense does it. |
They still don't do cat tests on diesels, just smoke test. As long as the oil burner is running sweet as a nut and they don't rev it to much it should be ok |
However we look at it I get it back tomorrow with no cats and a full stainless system with the back boxes taken out
Item 1 page 1....
but the shag pile will prevent them from seeing where it would have been |
Just get a permanent marker and stencil "DPF - Do Not Remove" somewhere along the exhaust, it's cheaper than fitting carpet and you won't have to vacuum it. |
hi mate can you wash and wax and hoover the bottom please |
| All times are GMT |
