![]() | Home > In Car Electronics > audio spec on HSE 2007 |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 ![]() |
trying to figure out the exact spec on the sound system on a 2007 HSE.
thanks Jas. guessing the 13 speakers are with the logic7 option?
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 ![]() ![]() ![]() |
there are more speakers in the audio system if the rear seat entertainment units are fitted |
i dont, but that is what im looking to do
crammy Member Since: 21 Aug 2014 Location: essex Posts: 167 ![]() ![]() ![]() |
I found contradicting Info on this. Mine is a supercharged charged hse and I fo I said was 14 speaker 550 watt standard on this vehicle. I neither have the logic 7 badges but it does have the six disc changer |
Mark1505 Member Since: 01 Oct 2014 Location: Wales Home, Singapore work & Also many other parts of the world, Posts: 57 ![]() ![]() ![]() |
I understand the spec in the link is in fact the USA model which I believe is slightly different spec to the UK model, with the HSE it depends also if its TDV6 or TDV8 as one has a slightly higher trim level from the other. If you check your stereo model number you will be able to find out if its the Logic 7 or just the basic HK system Java Black 2007 TDV8 HSE (my first RRS)
