| RRSPORT.CO.UK | ||
|  | Home > General > tdv8 engine |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | You won't get that answer as LR will keep the core unit and never reveal the cause of the failure. I asked, demanded and even got my Solicitor to write to them but answer was damaged beyond identification of cause.
|  Thu Oct 23 2014 7:21am |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      |
 If you peruse the FFRR forum, you will find turbo failure is just as common. Just finished a pair of turbo's on an FF. Actual cause of failure was "lack of oil" as diagnosed by a turbo specialist (req for warranty claim) Upon replacing the oil feed pipe, it was found to be mostly blocked. It may be worth replacing said feed pipe every few years, as part of routine servicing... | ||
|  Thu Oct 23 2014 7:45am |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | "Upon replacing the oil feed pipe, it was found to be mostly blocked. It may be worth replacing said feed pipe every few years, as part of routine servicing"
|  Thu Oct 23 2014 8:10am |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | Which leads to various other questions such as are LR using the correct oil when servicing vehicles. Ford had this issue with CVH engines when I worked for them and head/engine replacements were common at low milage. They ended up changing oil specs at dealers to prevent Black Death in engines.
|  Thu Oct 23 2014 8:21am |
 Not looked at a TDV8 Sport since, but the FF is fairly straight forward. A bit fiddly mind, but what job isnt   Will bear it in mind next time I have one in my hands, unless someone local to me has a TDV8 we can inspect sooner   | ||
|  Thu Oct 23 2014 11:07am |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Top man - pity you are so far away
|  Thu Oct 23 2014 4:53pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | In this case, it was the feed pipe that was blocked, No 4 on the picture
|  Thu Oct 23 2014 6:05pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | My TDV8 has been at the dealer since last Wednesday (hopefully picking it up tomorrow) with a blown turbo - the second time in three months. I advised them to at least clean out the oil pipes. My guess is that they won't have done so, of course. I expect another turbo to blow again in the next couple of months... 2012 SDV6 - it's missing a couple of cylinders
|  Thu Oct 23 2014 8:12pm |
| Posting Rules
