Home > General > RRS front wiper problem
rigpig100
2008 Range Rover Sport TDV8 HST Santorini Black
Wifey was using the RR last night, she says the wipers will only go half way across the screen, motor is still working, any ideas guys please.
Bob
Post #439556 Thu Oct 16 2014 8:59am
simple1
Have you had a screen replaced recently or battery changed? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #439569 Thu Oct 16 2014 10:57am
Paddi
It has been known for the wiper arm to driving spindle connection to work loose - it happened to the O/S arm on my TDV8. Easy to check - make sure the wipers are in the 'park' position and pop the bonnet so you can access the bottom of the wiper arms, prise out the circular sealing grommet and check tightness of the nyloc nut underneath.
If no problem there and the motor is running fine then suggests the linkage is at fault - quite easy to access by removing the scuttle trim panel. 2008 MY Java Black TDV8 HSE
Post #439570 Thu Oct 16 2014 10:59am
rigpig100
nothing has been changed, I can hear the motor going, and if I help the wipers move they do so with very little effort, but as soon as I let go of them they stop !
Bob
Post #439571 Thu Oct 16 2014 11:00am
Paddi
Perhaps a linkage problem then:
£55 on ebay complete with motor?
http://www.ebay.co.uk/itm/like/27111410785...p;ff14=108 2008 MY Java Black TDV8 HSE
Post #439577 Thu Oct 16 2014 11:31am
rigpig100
Cheers guys, I will get it looked at before buying bits I might not need, just got to find some one local as I cant drive for a month due to heart attack on sunday, so need to find some where close that wifey can find.
Bob
Post #439578 Thu Oct 16 2014 11:43am
cootsie
Scotland
Where about are Bob. I'm close to Turriff and there's a couple of places that would be able to help rather than a LR dealership.
Post #439580 Thu Oct 16 2014 12:33pm
rigpig100
Thanks any way mate, but I live in Norwich, Englandshire.
Cheers any way
Bob
Post #439581 Thu Oct 16 2014 12:35pm
cootsie
Scotland
Closer than Angola though... Laughing
Post #439623 Thu Oct 16 2014 8:36pm
BKHK
Blimey, I knew you had the odd issue with the RRS but a heart attack? Hope you get better soon Piggo, then back to Africa! Maybe buy something more reliable Rolling with laughter Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #439695 Fri Oct 17 2014 1:44pm
rigpig100
All sorted thanks guys, the drive had slipped on the motor shaft, easy fix, Glad I did not order a new motor at 160 quid.
Post #440275 Thu Oct 23 2014 2:55pm
Paddi
Excellent result Thumbs Up 2008 MY Java Black TDV8 HSE
Post #440340 Fri Oct 24 2014 2:41pm
