![]() | Home > Faults & Fixes > Fixed the leaking air bag strut, now all going down instead |
Set it at your normal height and then before you lock up for the night, remove the suspension fuse (in the engine bay fusebox). That will stop it from self levelling. If it goes down, you know that there is a further leak, usually the valve blocks (one at front and rear and a centre one) if it's not pipework joints etc. Bodsys Brake Bible
szki49 Member Since: 22 Oct 2014 Location: South Posts: 12 ![]() ![]() ![]() |
Thank you for the info, and so quick too.
ive just been out to check in works car park and the suspect rear driver side is again down,
Have you tried this?
Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
As Ian says, that is the only way to determine an air leak.
Put or spray some washing-up liquid on the joints you disturbed and check they're all airtight. If so work back the system on each joint, pump and check pipework for chaffing. |
Pulled the relay out.... Waiting game |
After 24 the whole truck has settled lower with the suspension relay out. It hasn't gone lower on the rear right this time it's all square.
The relay doesn't provide the ECU with power, only for the compressor.
Thank you that will be tonight's new attempt--- 👍👍 |
I pulled the fuse this time- (F26 If I remember right) and this morning it was only down on the rear right the side that was always the worst. The rest had held itself up, which looks like it hasn't tried to level (as the lack of fuse wouldn't allow it)
You have an air leak in that corner, or the pipework to that corner, or a leaky valve block |
Great thank you. Is it easy enough to get to the block? So I need to remove anything to get at it?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9131 ![]() ![]() ![]() |
The rear valve block is on the front face of the rear N/S suspension turret. You just need to remove the wheel. Also, remove the spare to give you another approach route. It's about £100 for a new one. Make sure you get the correct one - the front and rear valve blocks look the same but they aren't the same. 2012 SDV6 - it's missing a couple of cylinders
