![]() | Home > Maintenance & Modifications > transmission oil change overdue i think |
| tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917
brave guy. how much old oil did you get out Dan? I'd like this done soon and toying with the idea of doing it myself. Is it simple enough?
| Dan Stevens Member Since: 19 Aug 2013 Location: Brisbane Posts: 47
I actually didn,t drop the oil pan and filter. I drained it with the intentions of doing so but having seen how bad the oil was i just drained it and re-filled it with the intentions of doing it again this weekend.
| idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61
My suggestion with anyone working on oil changes with the transmission system of any car is to always make sure you can remove the refill plug before you drain.
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
Dan - looks like you have had the steel pan conversion - not so easy to do if you still have the original plastic sump.
no it hasn't had the conversion.
i too am an engineer by trade...... and i agree fully. this also applies to diffs/engines/brakes etc. Always check where you fill something can be accessed before you empty. |
So you sucked out the oil through the filler hole (I didn't think the plastic sump had a drain). Just interested as I have to do all this myself. Where did you get your Lifeguard 6 from? Cheers Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
the drain plug on the plastic sump is near the cross member, undone with an 8mm (i think) hex head, refitted to a max of 8Nm.
