![]() | Home > Faults & Fixes > Range Rover Airbags |
| rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150
Should be fine to reconnect the battery so long as you have checked all connections are properly secured. Have you had the car on a diagnostic machine as you may find the air bag ecu will have stored crash data and the light will not go out. If so the ecu will have to be Virginised and re-programmed to the vehicle. Specialist job but there are people out there that can do it for you. You can send just the ecu to them for repair. |
| All times are GMT |
