| RRSPORT.CO.UK | ||
|  | Home > General > Range Rover sport 2008 - pulls to the left |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796    | Sounds like the wheels are out of their specified range for offset and balancing sounds squiffy too.
|  Mon Oct 06 2014 9:23am |
| thisnamesux Member Since: 12 May 2014 Location: Camberley Posts: 5  | Hunters Land Rover are doing the tracking, balance, 4 wheel alignment...
|  Mon Oct 06 2014 9:27am |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796    | When I took delivery of mine back in 2012, it came with a significant 'pull' to the right.  Turned out to be too much 'toe out' on the R/N/S wheel causing the from to drift right, more noticible at increased speed.  Was like night and day when it was correct.
|  Mon Oct 06 2014 9:48am |
| thisnamesux Member Since: 12 May 2014 Location: Camberley Posts: 5  | I had my friend who works at hunters look over it, and he took it in to do the tracking / wheel balancing -
|  Tue Oct 14 2014 10:07pm |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | If you are still running on the tyres you were before alignment then it will pull slightly as wear will be off, new tyres and I'm sure it will go if alignment is spot on. Mine pulled left just before tyres were illegal. After fresh tyres it would drive straight. 2x TDV6. SE and HSE. Both returned to sender with issues👀
|  Tue Oct 14 2014 10:21pm |
| Peterlondon Member Since: 14 May 2014 Location: Bucks J5 M40 Posts: 80      | I found my MY14 pulled to the left when I first bought it, it was fitted with 22"wheels at that time. Swapping to 20" wheels has removed that tendency except on roads with very severe camber. MY2010 TDV8 purchased Jan 2017
|  Wed Oct 15 2014 4:25am |
| tailormadefun Member Since: 06 Apr 2014 Location: Kent Posts: 51      | I had the same thing, turned out to be a knackered wheel hub! | ||
|  Wed Oct 15 2014 6:53am |
| Posting Rules
