![]() | Home > Maintenance & Modifications > spruce up the interior! |
| Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852
Mark I did something similar except I did the whole dash in piano black with silver. Here's a photo:
For the gear selector surround I simply masked the area where the illuminated symbols are with a rectangle of masking tape and that was it. This was an attempt to make it like the 2012 RRS. See below: My attempt (well garages actually
2012 RRS:
This gave me almost the desired result, but I want to take it a step further and have circles around the symbols, and not a huge oblong 'cut-out'. I considered using the silicon 'feet' you can buy to mask the symbols, however, this is unlikely to work as the paint will most likely react to the silicon giving a poor finish a bit like fish scales... I've therefore considered the foam or felt type and will eventually try these. You can buy them in all sizes and shapes and therefore should be able to find a suitable size. The end result will give you a circle around the symbol with the OEM colour as background and your chosen colour as foreground. I will then replicate this for the Terrain Response dial. Hope this gives you some ideas and is helpful in someway, at least in what not to do... Cheers Guy Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" |
| jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
Hi guy not sure I understand these silicon or foam feet. Google returns exactly that; human feet made of silicon! 07 TDV8 + BAS map |
I mean something like these. They are self adhesive come in various shapes and sizes. Supplied in silicon, rubber, foam, felt etc.
So presumably you stick these on then paint over the surround if I understand its use? 07 TDV8 + BAS map |
