Home > Technical > Newbie center diff question
spooky
Switzerland
Hello!
Is the center diff a visquous limited slip?
Why do I see an "unlocked" icon on my dashboard then?
I have RRS 2012 V8SC, free rear diff.
Thanks!
Post #438973 Fri Oct 10 2014 7:50am
rich_sargie
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
I'm not entirely sure but I thought it was a torsion type diff in the middle. I could be wrong but it is defiantly not a viscus type as this is essentially an aggressive on or off type diff only realty suited to hammering round a track lol
Post #439049 Fri Oct 10 2014 10:18pm
The centre diff is a multi-plate wet clutch with the locking function provided by an electric motor. The motor is the same one that is used to implement changes between low and high range. The system allows for a varying degree of diff locking based on the Terrain Response settings chosen. Locking occurs automatically depending on the traction and the TR settings. It can not be locked manually by the driver. In TR "general" (special programs "off") the centre diff is effectively open all of the time - traction is controlled by the TC system alone.
Even when in a TR special program (mud and ruts, rock crawl etc.) it's open most of the time. The only time it will lock is if the system senses loss of traction at one axle or where the TR settings specifically ask for it. For example, in rock crawl mode, the centre diff will usually start off locked.
If you ever take your RRS off road you will see the centre diff lock up as conditions demand and depending on the TR settings chosen. If you never take your RRS off road and never use a TR setting other than the general "special programs off" setting then you'll never see the diff lock.
It amazing how far you can get sometimes before the centre diff locks. 2012 SDV6 - it's missing a couple of cylinders
Post #439059 Sat Oct 11 2014 2:06am
spooky
Switzerland
Thanks so much for the answer!
I looked everywhere I could on the internet, to get more info about this multi plate system on the RRS....and found nothing! Shocked Do you know any website where i can find this type of info?
The most interesting page a I found so far was:
http://en.m.wikipedia.org/wiki/Four-wheel_...h_coupling
...But it's not specific to the RRS! Rolling Eyes
Post #439129 Sun Oct 12 2014 7:55am
Is this of any use?
http://www.rrsport.co.uk/gallery/albums/us...%20box.pdf
Also, this is very informative - and a little scary that some key components are plastic...
http://www.rangerovers.net/forum/6-range-r...rdown.html
Interestingly, the centre diff in the previous FFRR (not the new one) was a Torsen system.
http://www.fullfatrr.com/gallery/albums/us...ferBox.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #439202 Sun Oct 12 2014 9:46pm
spooky
Switzerland
Wow, I already checked the first link, it is an amazing piece of information! I'll check the 2 other links this evening (I don't understand why I was not able to find this info myself... Wink ). Really thanks a lot Very Happy (and yes I was also confused by the variety of limited slip technos that were used at LR...).
Post #439217 Mon Oct 13 2014 5:25am
The first one didn't exist until last night - I extracted it from the workshop manual for you. Thumbs Up
The second link came from searching for the transfer box by its name (DD295) which is in the workshop manual. The third link was just something interesting that fell out of my searches. Thumbs Up
The DD295 is used in the D3/D4/RRS1. The previous FF and the FL2/Evoque use Torsen centre diffs (not the same one though, I'm sure).
The new RRS uses a multi plate clutch in the two speed transfer box or a Torsen diff in the single speed transfer box. The latter is set up to give more torque to the rear end (42/5Cool in normal conditions and can send a maximum of 62% to front / 78% to rear. The two speed box is set up 50/50 and can send 100% of torque to either end. Based on that, I would like expect the two variations of RRS2 to handle differently on road and perform differently off road. 2012 SDV6 - it's missing a couple of cylinders
Post #439224 Mon Oct 13 2014 9:47am
I've seen that the FFRR adopted the same gearbox and transfer box (and hence centre diff) as the Disco and RRS in 2007. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #439247 Mon Oct 13 2014 1:48pm
spooky
Switzerland
The post of RRPhil was absolutely amazing! Very Happy
Post #439492 Wed Oct 15 2014 6:51pm
