![]() | Home > Maintenance & Modifications > Can anyone with experience in soldering give advice? |
| tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917
So, I'm truly exhausted having searched everywhere for a set of angel eyes with 5 led's per ring. I've even contacted China, but got fed up when they started sending me offers to buy all sorts of lights, teddy bears, you name it |
that's a pain, though I've heard that the diodes sensitive to burning. Maybe buying them from a German supplier will make a difference, we'll see.
| sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588
Oh my god, Sh**ts just got real when the mans trying to make his own DRL's |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961
have you looked at the following site http://www.auto-lighting.co.uk/
Just looked at the LED's in your link and they are the right ones.........maybe it could be possible
"Sparky" well yes now it all makes sense |
been there several times but too many diodes on the rings DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
[quote="sparky8181"]Just looked at the LED's in your link and they are the right ones.........maybe it could be possible
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
Have you tried...
Yeah a resistor of some sort, its got "IDE" printed on it I know this isn't much help but I've just gone through 7 pages of PM's looking for a fella who had a set off me but never got round to fitting them as he swapped his sport for a Vogue and asked me if I wanted them back (at the time I didn't), but cant for the life of me remember his name. Sure he was Scottish and sold his sport for a grey Overfinch Vogue, if your reading this LUKE WANTS TO BUY YOUR DRL'S..........get in touch |
if you are still hell bent on making your own rings, you will need to know 3 things in order to calculate the size of resistor needed to lower the voltage to the correct level :
thanks for that gogsy! Worked very nicely indeed, although I had to adjust the forward voltage to 2.3 from 3.2 in a series circuit, or the total voltage would have been more than 12v. I don't know if that makes any difference making this change. i'm sure the resulting light will be very bright indeed.
TL, its good practice to get the voltage as close as is required for the LED's as it will affect the brightness, but more importantly, it will reduce the life of the LED especially if it is too high. 2010 RRS, TDV8
will it make any difference then if i connect them in parallel, with each diode having its own resistor? this is getting complicated. will the led's then be brighter, or doesn't it make any difference? Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
| All times are GMT |
