![]() | Home > Maintenance & Modifications > Changing the master cylinder |
| Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245
Yes, you can bleed in the traditional way. You may have to bleed as far as the ABS modulator first, to get the fluid moving, then at the wheels.
| K80tcg Member Since: 29 Mar 2013 Location: Verwood Posts: 25
Thanks for that.
I just cracked a pipe union on the ABS modulator and bled in the old fashioned way, with an assistant pumping the pedal.
| All times are GMT |
