![]() | Home > General > Where is the fusebox on the MY2010 RRSPORT how do I locate |
| fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216
http://topix.landrover.jlrext.com/topix/co...tabs=false
| Nav01 Member Since: 18 Jan 2013 Location: North London Posts: 99
Hi FKarim
Mine is a MY13 and no I don't get front display on the nav screen. I suppose it would only be possible if you have surround camera system which I don't - only got rear. |
| designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338
Done a search for this as my reading lights all round the cabin won't light after replacing a led bulb. It was going so well. Literally my last two bulbs and the interior looked so fresh. But now I can't get them to turn on. Very sad. |
There are probably different fuses for "map reading lights" and footwell lights. Also, remember that power is supplied to these lights only for a short period of time after switching ignition off and opening the doors etc. Did you try giving it a rest by locking the car or just closing the doors then coming back to it later? The lights might work later if they simply switched off because of that timeout. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
Retrace your steps. It maybe that the Canbus has shut down system as there isn't enough resistance. I had same issue with my under mirror puddle lights, worked with one led in n/s, soon as fitted o/s no light. Bought two canbus LEDs and problem solved. 2x TDV6. SE and HSE. Both returned to sender with issues👀
I bought a full kit - about £40 to do all the lights, I was loving it, looked great and then I got to the last two lights, they now both don't light or the two either side of the middle light at the front, currently looking for my book to find where the fuse box is. I can see what fuse it is but not how to open the glove box to reveal it lol. It is making me feel rather dim right now as I know it is there! |
