![]() | Home > General > How will 2012 range sport handle in snow? |
| paulL Member Since: 20 Dec 2005 Location: Barcelona Posts: 263
On winter tyres it is really very good. For steeper descents, you can use hill descent control HDC and adjust the speed using the cruise control speed adjust buttons. 2013 RRS SDV6 Autobiography Fuji White
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
If it's on winter tyres and you make use of Terrain Response - Snow/Grass/Gravel then you'll find that it uses HDC when you're in the correct speed range. It'll also give a much softer throttle response which gives less chance of wheel spin when starting off. It changes the TC/DSC settings too.
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
It weighs 3 tonnes so don't expect miracles, especially on ice - that's a lot of momentum. Do everything very gently and you'll find there's not much will touch it for ability.
| spooky Member Since: 15 Feb 2014 Location: Swiss Posts: 34
The HDC was indeed fine on the FL, a bit too slow maybe |
^^^^ Shshhh ! you're not supposed to tell anyone - I thought this was a secret "...(in Switzerland you have snow and money Laughing ) " |
Braking distances will be tyre dependent. I would expect that with the right tyres it'll be little different to the FL.
Tires will be Michelin la2. |
| sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961
Sometimes I drive to Vevey at Christmas and I have never had any trouble. You are rite that driving in Switzerland everyone is prepared for snow. I have Michelins on mine and had no problems with them. My last sport had Pirellis which were brilliant . My sister lives there so accommodation is very reasonable. |
Wow, you're from weymouth (England?) and you know our little city of Vevey! |
| andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155
It's as much about your own driving ability in the snow and knowing your limitations, and the cars capability and understanding
| All times are GMT |
