![]() | Home > Wheels & Tyres > Winter season wheel change. |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 ![]() |
im leaving my 22s on! woop woop
Batmau5 Member Since: 23 Sep 2014 Location: South shields Posts: 3 ![]() ![]() ![]() |
No chance. She will be driving it most of the time so they'll be ruined |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9153 ![]() ![]() ![]() |
19 inch rims with 255/50 tyres will give you a deeper sidewall than 20 inch with 275/40 tyres. Usefully raises the rim slightly higher so less danger from kerbs - especially useful if the vehicle slides a bit against a kerb in icy conditions.
That's helpful information, thank you. Is there any other type of wheel that will fit straight on or is it purely LR wheels? |
No idea what rims fit other than LR ones. As you need a high load capacity rim I'd be very careful using anything other than LR RRS rims unless you can ensure the load capacity. Some aftermarket rims will struggle with the weight of a RRS - especially if it's near to GVW. 2012 SDV6 - it's missing a couple of cylinders
Mark1505 Member Since: 01 Oct 2014 Location: Wales Home, Singapore work & Also many other parts of the world, Posts: 57 ![]() ![]() ![]() |
Hi
I had these wheels fitted to my sport. Although my sport didn't have Brembo brakes, i do know that these wheels fit over Brembo's.
Hi Ady,
lazysteve Member Since: 17 Dec 2011 Location: Bulgaria, Nessebar Posts: 13 ![]() ![]() ![]() |
Hi, I can tell you 19" wheels will not fit with brembos. I had 20" summer wheels and 19" winter. I had the brembos fitted after the purchase of the car. It was during the summer so didn't really think about the 19"s. Along came winter, off to the tire place with the 19"s in the boot. Back ones fitted fine, then found the guy trying really hard to force the front ones on.
foxtrotzulu Member Since: 04 Sep 2015 Location: West Berkshire Posts: 152 ![]() ![]() ![]() |
I know nothing at all about brakes, but I thought I'd read on here that The OEM brakes were Brembos but just without the label. If 19inch won't fit does that mean the labels are very thick? |
I have 19 inch rims on my TDV8 which has Brembo brakes. They fit fine. 2012 SDV6 - it's missing a couple of cylinders
4-pot or 6-pot though? ![]() 4-pots are min 19", 6-pots min 20". ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Hi, 4 pot or 6 pot?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5152 ![]() ![]() ![]() |
This is a 6 pot on a 21" Rim not a lot of room.
