Home > Technical > What headlights?
micalee
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
What headlights?
Travelling back tonight along M5, keep seeing loads of high end Mercs with really bright white headlamps - what bulbs do they use? LEDs, HID? They are OEM and make my xenon look like halogen[/img]
Post #438075 Sun Sep 28 2014 9:58pm
JDF1
England 2010 Range Rover Sport 3.0 TDV6 SE Bonatti Grey
If your system is working efficiently. Your Xenon bulbs are likely to be factory originals and as such they will probably the lower end of the spectrom at 4000K the system you have is capable of taking an upgrade of bulb from either Philips or Osram which will bring it too 4800K. These numbers are the brightness that the xenon burns at when ignighted so the higher the number the better the brightness. But if you are doing this yourself whilst quite straighforward the bulbs are very sensitive to sticky fingers on the glass or element so be very careful. They are also quite expensive at £120 a pair or there abouts. There are alternatives but they wont last as long.
It wont take a vehicle electrician long to determine if yor system is working properly which would then allow you the piece of mind to invest in some better bulbs.
hope that
Jody gone but not forgotten 2003 4.4 RR Vogue
Post #438237 Tue Sep 30 2014 10:06pm
idrabble
Australia
4000K or 4800K is not an indication of how bright the bulbs will be, it is the colour temperature on the Kelvin scale.
1000K is basically red through to 10000K upwards is Blue.
The 4000K to 5000K range is in the yellow area of the spectrum.
The higher temperatures will look brighter, but I think that technically they are no brighter than any other colour.
Post #438242 Wed Oct 01 2014 4:58am
Gargy
England 2009 Range Rover Sport TDV8 HSE Santorini Black
From what I have read, car makers are trying to emulate normal daylight with HID lighting.
The colour is measured in Kelvin, and daylight ranges from 5,000 to 6,500 Kelvin depending on time of day/season.
Lower dond the scale makes light more yellow, and higher makes it more blue.
Personally I have a LED headlight on my motorcycle, which is better than the HID's on the RRS....... IMHO.
Post #438245 Wed Oct 01 2014 7:06am
DaveB
Re: What headlights?
I think you may have seen these...
Post #438247 Wed Oct 01 2014 8:21am
micalee
Thanks for the words - I cannot view the Youtube at work so will look when home. Are the Mercs then LEDs or 4800 bulbs?
Post #438252 Wed Oct 01 2014 9:51am
DaveB
The newest Mercs are LED's as shown in the video. Some clever stuff going on with them. Worth a watch when you get home.
Post #438253 Wed Oct 01 2014 9:55am
micalee
Will do - they were fantastically clear and bright white without being dazzling by some of the 'older' cars I have seen which have modified bulbs/HID or whatever they do.
I would just like brighter than I currently have, even though they are Xenon, they now look like Halogen compared to the Mercs and perhaps other manufactorers adopting the same technology!
Anyone upgraded their OEM Xenons with good results?
Post #438260 Wed Oct 01 2014 11:03am
jimbg
As mentioned above 4800 is "yellow" end of spectrum, you need 6000k bulbs if they exist. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #438261 Wed Oct 01 2014 11:09am
bigdavy60
2005 Range Rover Sport TDV6 HSE Java Black
ive just ordered a pair of 6000k bulbs from ebay so will keep you updated with the result when fitted , mine are presently very poor on dipped beam
Post #438270 Wed Oct 01 2014 2:33pm
micalee
YOu have OEM Xenons?
Post #438276 Wed Oct 01 2014 3:51pm
bigdavy60
hi i think thats what i have they have a balast unit on rear of bulb , numbers on bulb were D2S 6000k so have just ordered a similar bulb although i guess the quality wont be the same as the osram make im taking out due to price ?
Post #438283 Wed Oct 01 2014 6:29pm
micalee
Interested to see outcome. Smile
Post #438373 Thu Oct 02 2014 8:05pm
bigdavy60
Well I just fitted the bulbs and both headlights are perfect really bright so defo a result for now Thumbs Up
Post #438442 Fri Oct 03 2014 4:27pm
micalee
Brill - can you send link or details of what you purchased.
Post #438465 Fri Oct 03 2014 10:02pm
