Home > General > Tow bar
Leeser23
United Kingdom 2007 Range Rover Sport TDV8 HSE Siberian Silver
Tow bar
Evening all,
Bit of advise please guys, the sport I bought last week has a detachable tow bar fitted which is great .
I finally found the key in the boot and after spraying the lock for a week I can now turn said key and twist the green knob.
At this point should the tow bar just pop out downwards ?? My guess is it seized and will need a blow with a hammer ??
cheers
Nick 2007 HSE V8, steps fitted, interior & reversing LED's, Black badges
Post #437904 Fri Sep 26 2014 6:34pm
If the removable part has been in the socket for some time then it may well be seized. It's not unusual. There have been a number of threads about it and quite a few suggestions about how to free the bar. I think a good smack is one of the options but not sure how successful it is. 2012 SDV6 - it's missing a couple of cylinders
Post #437906 Fri Sep 26 2014 6:42pm
MAW
Also - I think you need to pull out - to the right (as you look at it) then twist to unlock. They are prone to needing persuasion though....
Wouldn't want you whacking it if it was free Laughing
Post #437907 Fri Sep 26 2014 6:51pm
Gargy
England 2009 Range Rover Sport TDV8 HSE Santorini Black
Mine got 'stuck' so to speak, and I tapped it side to side with a nylon headed hammer.
If you do get it out this way, make sure you don't trap anything under the towbar, as it is heavier than it looks.
Good luck.
Post #437909 Fri Sep 26 2014 7:15pm
Leeser23
Well after lots of lube and a whack she dropped out !
Yes I was also surprised by the weight 😄
Thanks guys 2007 HSE V8, steps fitted, interior & reversing LED's, Black badges
Post #437989 Sat Sep 27 2014 9:01pm
