Home > General > Adaptive cruise control
362bkr
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Am I missing something here ? I love the ACC on my car but when I go to overtake a large vehicle like a truck or coach the system/radar senses the vehicle and slows down . Can this setting be adjusted if so how ? I must admit this has been bugging me for a while Confusedi
Post #437286 Sun Sep 21 2014 11:33am
myfirstrrs
you need to override the ACC with the accelerator in such situations. If I understand you correctly the ACC is just doing its job by slowing you down when it sees an object ahead.
Post #437289 Sun Sep 21 2014 12:02pm
362bkr
No not really it sees it when it is beside me so I wondered if the radar beam (width) could be adjusted otherwise I would be unable to for instance overtake a line of say 6 hgv s on cruise ?
Post #437292 Sun Sep 21 2014 12:07pm
Andi
Never had that, as I pull out, the car recognises that the route ahead is clear and accelerates up to set speed.
Post #437296 Sun Sep 21 2014 12:14pm
myfirstrrs
So does mine. Throttle override is just to get clear of the vehicle in front of me for the radar to find that clear stretch of road. Without throttle override it is too slow and cars behind don't like it.
Post #437297 Sun Sep 21 2014 12:18pm
362bkr
Yes I can pass cars all day long on cruise but not wider vehicles ..........
Post #437298 Sun Sep 21 2014 12:18pm
Sounds like it needs to be adjusted. As you say, once you pull out the system should recognise that and accelerate up to the set speed. I find the decision to accelerate can take a few moments sometimes so a little prod of the loud pedal helps. 2012 SDV6 - it's missing a couple of cylinders
Post #437299 Sun Sep 21 2014 12:20pm
simple1
You can adjust the distance it reacts. It works well on an A road but on motorway its a pain in the bum if you drive "properly" ie using lane 1. If you come up behind a unit it slows down which is a bit annoying. My truck has a similar system but you can adjust sensitivity and distance. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #437329 Sun Sep 21 2014 5:11pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
What really bugs me with it is the braking, its like a child is driving, it can be really harsh, when I see the care ahead start to break I take over, the auto version is terrible. Can you update this in the computer to feather out to a stop?
Post #437360 Sun Sep 21 2014 10:16pm
I think it depends what gap you have set. If it's set to run a short distance behind the braking is more sudden. 2012 SDV6 - it's missing a couple of cylinders
Post #437363 Sun Sep 21 2014 10:24pm
Alex C
2008 Range Rover Sport TDV8 HSE Java Black
Does anyone else find the car shifting down soon as you hit a hill?? Mine does it all the time on a motorway with cruise set and it is really irritating. Always wondered if that was normal? TDV8 Java Black, Overfinch 22s
Post #437366 Sun Sep 21 2014 11:24pm
designboy
I tried both, must make a note on how more aggressive it is. For me its not right. But its a classy feature.
Post #437367 Sun Sep 21 2014 11:35pm
362bkr
but how do you set the gap ?
Post #437382 Mon Sep 22 2014 8:45am
rigsby
There is an adjustment on the left hand side of the steering wheel in the opposite place to the heated steering wheel switch MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #437386 Mon Sep 22 2014 9:18am
myfirstrrs
Mine also shifts down when it sees a hill, far too readily in my opinion and I always think it will use more fuel that way. You expect this on a proper hill but not on a slight rise.
Post #437391 Mon Sep 22 2014 10:04am
