![]() | Home > Maintenance & Modifications > Splitting the headlights |
I've not done it, but I think the riskiest part is getting the temperature right to enable the glue seal to melt enough to pries them apart.
Gordon2010 Member Since: 17 Sep 2014 Location: Kilmarnock Posts: 17 ![]() ![]() |
It's not to bad done mine last week, get a good heat in to them with a hair dryer then start prising them open |
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
But don't use a screwdriver as awdman did as he has warped the edges where they split, instead when I did them again I used a wall paper scraper as the wider blade opens it better. IMO I wouldn't do it, awd mans kit was wasn't in two years before they failed and I had to split then again. |
Astra012 Member Since: 31 Aug 2014 Location: Cardiff Posts: 51 ![]() ![]() ![]() |
Thanks for the replies think I might give it a miss, I'm useless at diy and knowing me I will mess it up!!! |
