![]() | Home > Technical > Speedo discrepancy? |
| stealth Member Since: 09 Jul 2014 Location: Hampshire Posts: 30
Mines reads a little slow |
| micalee Member Since: 24 Apr 2014 Location: Warwickshire s Posts: 241
Cheers for the response |
| Brian Member Since: 17 Sep 2013 Location: Kirkcudbrightshire, South West Scotland Posts: 37
As does mine. Cheers
So, guess we all have to be careful through the speed traps then as our speedo's read wrong! |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
Speedometers on most cars are optimistic reading higher than your road speed so if your speedo say 70 your road speed will be lower ( and you'll be inside the law.
But it's the other way round unless I am confusing myself. My speedo says 70 but cruise says 68 and i guess my cruise is more accurate in which case when my speedo says 70 I am actually doing 72 |
| RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797 |
I've just done a test on way home.
Im gonna try my TomTom and see who is lying - speedo or GPS! I know you get a fudge factor with speed limits, but don't want to be doing 70 when I am actually doing 72/73! |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
Read that again. You've just confirmed that your cruise is more accurate than your speedo so, if your cruise says 68 when your speedo says 70 then you're likley to be doing 68, not 72. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Yes you're correct - I knew I confused myself!. When I have had my TomTom on with other cars, my speedo has always read higher (i.e speedo says 70, TomTom says 6 |
| All times are GMT |
