![]() | Home > General > How easy is to steal my car? |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 ![]() |
cut, or take out your OBD2 connector under the dash. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9074 ![]() ![]() ![]() |
Just check the car is actually locked when you plip the remote. |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 ![]() |
Joche
Bungleaio Member Since: 06 Apr 2014 Location: Leicester Posts: 172 ![]() ![]() |
Its the new ones with keyless that are the easy ones to steel. |
I've been told to remove the cable completely? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4483 ![]() ![]() ![]() |
By disabling the OBD port, a new key cannot be coded to the car, and driven away |
Thabks mickey. My cars in the garage so I will ask them to dis able it. Will that have any other affect on my car? |
It could potentially void any warranty you have. It will also make it more difficult for any garage you take it to trying to sort a problem. They would have to enable the port, do the work and then disable it again. Sounds like a recipe for disaster and excuses. 2012 SDV6 - it's missing a couple of cylinders
A hidden switch would work wonders |
Disco mickey
