![]() | Home > Technical > Running on 5 cylinders |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
An hour to take out all 6 injectors is time consuming, and expensive?
W18ODY Member Since: 31 Aug 2014 Location: north east Posts: 87 ![]() ![]() |
Just to add to the list of problems (not sure if its related) the cars sat for a few days and i went to turn it over and it really struggled, really weak cranking then eventually gave up.
You have to have the injectors tested, to find out which one is faulty... EDIT: There is the option to view the injector compensations via the diagnostics, but the OP has not mentioned having had this done. Over and above this, I have been in the position in the past where the car was showing 1 injector fault. This was replaced, and the fault moved to the next most worn injector. This continued until all 6 had been replaced, hence the suggestion to have all 6 tested at the same time To reseal the injectors, you use a new copper washer... When the fuel system has been disturbed, all open connections should be capped to prevent dirt ingress. Explicitly stated in most repair instructions issued by LR ![]() |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 ![]() ![]() ![]() |
the op wants to find out what is wrong with his car,
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
Take the injectors out and get them tested its a piece of |
