![]() | Home > Maintenance & Modifications > Hardwiring Blackvue Power Saver |
Hi Muddy, i had a faulty power saver, i'm awaiting delivery of a replacement which should be on tuesday, other than that, yes i'm all sorted thanks. |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5644 ![]() ![]() |
Just hardwired the Blackvue in the new RRS and had to read my own guide from last time to refresh my memory |
chrisebabes Member Since: 14 Jul 2010 Location: Cornwall Posts: 79 ![]() ![]() ![]() |
Great info thanks guys |
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 ![]() ![]() ![]() |
Hi Muddy, I am looking at fitting the Blackvue.
Tucked up into roof lining and down behind a pillar trim then through hole behind trim for bonnet release |
Thanks Muddy, photos would be great for a simpleton like me. MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
Sorry Ravingmad - just realised I never took the photos for you - did you manage or still want me to do it |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 ![]() ![]() |
I decided not to undo trim and the bonnet release but to extend the earth wire by a few inches, loosen the bolt at the bottom on the RHS of the glove compartment which is attached to the metal frame and push a "U"type connector down onto the bolt between the bracket and the plastic. Even if you don't get it seated right on the bolt it holds in place ok when the bolt is tightened. |
Strudelbaum Member Since: 07 Aug 2014 Location: Mijas Costa Posts: 38 ![]() ![]() |
Where did you guys install the camera? I wanted to put mine up on the windshield behind the rearview mirror. I'm just wondering how to run the power cable neatly from the fusebox. I guess I have to rip apart some of the moldings?
There is enough space to tuck the cable away behind the headlining where it meets the screen, then tuck it away behind the pillar trim. |
Cables as Ady said |
itsmeagain Member Since: 01 Nov 2012 Location: Birmingham Posts: 222 ![]() ![]() ![]() |
Good write up, gonna install mine over the weekend Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
Just being curious - what software are you using for viewing the dashcam footage?
