![]() | Home > Technical > Running on 5 cylinders |
W18ODY Member Since: 31 Aug 2014 Location: north east Posts: 87 ![]() ![]() |
Bump
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 ![]() ![]() |
(emphasis added) |
Cheers for the warning, can you shed any light on the rest of my issue? |
Could be many things - injector, worn/damaged valve guides - best get a fault code reader on it. I assume it's not been owned by you since new, so previous issues/problems unknown. |
Had it plugged in, only looked for fault codes though, should i be doing something more? for my seat/vw ive got software to run logs over different measuring blocks to determine exactly what different components are doing.
Read the codes it should tell you which cylinder is off, then swap that injector with another either from the engine and then see if the fault moves with the injector or replace if you have or can get hold of a spare, chech continuity in the injector harness, if these are ok then check compressions though you will probably not be able to remove the glow plugs to do this as they are well known for seizing and snapping but you never know !!
Cheers for the reply camelrock, ive heard about the glow plugs being stubborn so will the compression test be done by removing the injectors?
Only way to check the comps is by removing the glow plugs, as far as the valves go I don't know enough about these engines to comment, but I ' ve never heard of this before and I was on the Disco3 forum for 6 years though I'm sure someone with more nol will come along .. 2008 G4 RRSport TDV8 current
similarly ive never heard of a valve problem like it, my mechanic says the "wob wob wob" noise heard when the airbox is lifted is compression and if its heard in the inlet it must be a valve passing, ive only ever heard of or seen valves damaged when the timing belt fails so im stumped as to what it could be |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 ![]() ![]() ![]() |
its more than likely a bad injector, that is the most common cause of ruff running / loosing a cylinder.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4356 ![]() ![]() ![]() |
If an inlet valve was stuck open, the plastic inlet manifold would have likely melted.
you have pm rich
replied mate |
taking out all the injectors and doing a compression test is very time consuming and expensive. would it not be better to do some less intrusive test to determine which cylinder is fault and concentrate your efforts there? |
