![]() | Home > General > TDV8 gone bang 70k miles |
| jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
They happened to offer a good price for engine flush at last service and I took it ! Relief! 07 TDV8 + BAS map |
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
My service invoices have shown engine flush every time for the last three years. Both turbos went last month...
I wonder if the oil scavenger pump is marginal and so leads to the oil not been cleared from the turbos correctly...if so, the oil might be getting cooked in the return pipe reducing (and then blocking) its bore and flow leading to failing of oil seals and thus turbos. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
| R3JYS Member Since: 08 Sep 2014 Location: England Posts: 8 |
What mileage did yours fail at rrstdv8 ? |
78k miles. 2012 SDV6 - it's missing a couple of cylinders
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
It's not about pumps or oil pick up, and milage is not a factor in failures. Mine only had 8k on the clock the first time, 48k the terminal time and had a full dealer service history having been serviced three months and 3000 miles prior to failure.
Got both turbos off a TDV8 FFRR just now.
Was always careful letting mine warm up and cool down, always let it idle for 30 secs before switch off regardless of tiddling in traffic or spirited drive. Mine failed after being parked up for periods of time on each occasion so valid question. There are two trains of thought in mechanic circles, some say idling does more damage than not blah blah blah. In the case of a racing engine that is over fueling fair enough.
Update warranty direct have authorised full repair and I am just waiting for the car back
| 362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856
That's good to know |
| ADO5TIMES Member Since: 06 Jul 2014 Location: stoke on trent Posts: 63
Whoa happy days. What a relief for you. |
| andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155
best outcome.... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
| JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186
Great stuff. |
