Home > Faults & Fixes > Dynamic Response leaking
OceanCarl
Spain
It seems the two hoses going from the pipes to the actuator on the anti roll bar have bursted and are leaking fluid. The dealer say there is no single part number for these hoses and have to change the whole piping system for the dynamic response.
I think this is a bit overkill!?
Would be easier, I think, to cut the piping, install swageloks and have a new hose made by a hydraulic service man?
Anyone had this problem?
OC
Post #436107 Fri Sep 12 2014 5:45pm
Sorry, don't have any part numbers but this is from the workshop manual for pre-face-lift RRS:
Quote:
SYSTEM PIPES
Fluid is moved through the Dynamic Response system via a seriesof six pipes and hoses. The pipes are mounted on brackets at
strategic points to provide quiet operation of the system.
The six pipes connecting the pump, reservoir and actuators are one-piece components. If the pipes require replacement during
service, the pipes are supplied individually and are removed and replaced in one piece. The front and rear pipes require the body
to be lifted slightly to allow access for removal and replacement.
On TdV8 models from 2007MY, the high pressure hose and pipe from the pump to the valve block are available as two separate
service parts. The high pressure hose has a quick release connector located in a position below the Air Conditioning (A/C)
compressor. This allows the hose to be splitinto two parts to assist with service repairs. The connector is sealed with an O-ring
and a back-up ring which are available as service items. A special tool is requiredto separate the connector. The tool is inserted
into a slot in the connector, which separates the two components. It is not necessary to use the tool as a lever to 'push' the two
components apart.
The flexible high pressurehose which supplies pressure from the pump to the high pressure pipe is fitted with attenuators. The
attenuators comprise of tuned lengths of PTFE pipe and restrictors within the flexible hose. The attenuators damp pressure
pulsations in the hydraulic fluid producedby the pump, reducing noise and strain on components downstream. The attenuator is
integral with the high pressure hoseand cannot be serviced separately.
CAUTION: Under no circumstances during repairs should clamps be used on the high pressure hose or the front and rear
actuator feed pipes to prevent fluid loss. The use of clamps will damage the pipes and hoses leading to premature failure
Which pipe has failed? If it's the one with the attenuators in then a home-made one might not be suitable. 2012 SDV6 - it's missing a couple of cylinders
Post #436111 Fri Sep 12 2014 6:02pm
OceanCarl
Spain
Thanks RRSTDV8,
I dont have the workshop manual so this was helpful.
The hoses are the two inside the red circle in this photo:
They don't have a separate part number but I believe the part for the assembly is "RQA500120". Not to expensive, but a hole lot of trouble to change in my opinion.
I believe the attenuators are sitting higher up, near the pump.. Hopefully....
OC
Post #436158 Sat Sep 13 2014 7:17am
hodjie
United Kingdom 2011 Range Rover Sport Supercharged Autobiography Fuji White
been waiting 10 weeks now for these pipes from landrover Big Cry
Post #529417 Sat Jul 01 2017 6:20pm
Johnski
From memory if front and rear ones that are leaking, then unfortunately they have to lift the body of car to replace.
Unless I'm getting confused with other pipes, it was on here but search hasn't found the previous thread. Big Cry
Try getting in touch with Dan a Forum sponsor Duckworth Parts (listed under Sponsors at top of page) he will get price availability etc for you. He posts regularly on here. John
Post #529418 Sat Jul 01 2017 8:24pm
hodjie
its the front os one . the specialist said its because its the petrol model ,so only limited supply
Post #529420 Sat Jul 01 2017 8:42pm
Jaggs
Had to have mine replaced due to a leak last year, I seemed to recall they only came as a set at about £250, with the labour and replacement fluid the bill was about 900, I did have the single pipe replaced from pump to block at same time which was about £80.
Luckily the £90 RAC warranty paid £750 as I had to have car recovered as it had ditched all the ace fluid. Nanocom Evo
Post #529424 Sat Jul 01 2017 9:33pm
hodjie
oh god Shocked they told me the pipes should be £400 but for the supercharged its come in at £200 .but theres none in the country . if I'm going to have to chew on like this I think il find a different brand . I get my tvr cerbera and lotus elise sorted quicker then this
Post #529425 Sat Jul 01 2017 9:43pm
Jaggs
Took this screen shot from local Indy garage I use, it was posted last week so seems to be a common theme
 Nanocom Evo
Post #529426 Sat Jul 01 2017 9:50pm
hodjie
thanks for that Thumbs Up been looking at cayenne turbos tonight as an alternative ,and that's a first for me
Post #529427 Sat Jul 01 2017 9:58pm
Socast
The pipes can be bought individually, but it works out to be more cost effective to buy the 4 as a complete unit, individually each pipe costs nearly as much as the complete set, so you buy two and you've spen't more than it would cost to buy all 4..
The part number for the 4.2 is: RQA500018
Post #530087 Tue Jul 11 2017 10:17am
hodjie
hi ,thanks for the advice everyone . just had it in for a temporary repair , drove it home tonight and its still dumped half its fluid on the drive Big Cry
Post #530157 Tue Jul 11 2017 10:33pm
Johnski
Whatever is a temporary repair? Surely either repaired or not, for that fluid system. Rolling Eyes John
Post #530163 Wed Jul 12 2017 12:53am
41664166@online.no
Norway 2006 Range Rover Sport TDV6 Autobiography Rimini Red
Then I removed the plastic cover under the car on the driver's side. Found some gravel and mud there, so the pipes had rusted, and therefore holes in one. They were not pretty, so I wonder if I should change them all when I first do this. But found that they were not cheap, someone who has someone who can deliver at a nice price. Thanks in advance
Post #602740 Tue Aug 04 2020 7:05pm
41664166@online.no
Got repaired the leak in the pipes, but after filling with the right oem oil I experience a strange knock sound when I turn right. Is there any kind of blending for this system, or do the car it self.
What can it be ?
Post #603148 Tue Aug 11 2020 4:23pm
