Home > In Car Electronics > interior alarm
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
interior alarm
Hello lads, sorry if this has been covered but is it possible to turn off the interior alarm sensor? dogs keep setting it off... cant seem to get the search to work??
cheers
Post #435821 Tue Sep 09 2014 8:06pm
rigsby
If I remember correctly you press the lock button twice within 3 seconds to disable the interior sensors MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #435822 Tue Sep 09 2014 8:21pm
Bodsy
Site Sponsor
Yes, that's right. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #435829 Tue Sep 09 2014 8:52pm
looneyfitter
on the remote? really? Censored i thought that was dead lock.. i always double press
Post #435839 Tue Sep 09 2014 9:45pm
looneyfitter
thanks
Post #435840 Tue Sep 09 2014 9:45pm
gogsy1956
Shocked I was under the same impression........ Double press to arm the volumetric and perimetric alarms, I think it's time to check the Oracle, failing that the handbook mightier dusted off.! 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #435849 Wed Sep 10 2014 7:50am
frostmotorsport
New Zealand 2006 Range Rover Sport Supercharged Rimini Red
nope. press once and the lights flash 3 times to indicate that the perimetric and movement sensors are armed. Double press to lock without those armed. Every home should have one!
'06 RRS SC Rimini Red
'04 Audi S4 Avant
Escort Mk II Sport
Post #435860 Wed Sep 10 2014 10:06am
gogsy1956
Just checked through the manual and it states, press the lock button once briefly, this will single lock the vehicle and prevent the doors from being opened from the outside ( they can still be unlocked and opened from inside). The perimetric alarm is also turned on.
Press the lock button twice within 3 seconds this will double lock the vehicle and prevent the doors from being opened from the inside and outside unless a smart key is used. The perimetric and interior alarms will be turned on.
If required the interior alarm can be disabled through the system setup menu 2010 RRS, TDV8
22" overfinch
Post #435893 Wed Sep 10 2014 3:30pm
