| RRSPORT.CO.UK | ||
|  | Home > In Car Electronics > Retro Fit Phone Module 2010 RRS |
| RangeRoyer Member Since: 28 Jul 2014 Location: Worcestershire Posts: 21      |
 My recently purchased 2010 RRS HSE is not equipped with the Phone module.  Is it an easy job to add this? What cost is the unit?
|  Sun Aug 31 2014 8:20pm |
| viper Member Since: 21 Apr 2007 Location: chester le street Posts: 857      | im sure all hse had bluetooth phone connectivety as did the se on the 2010 my 2016 bmw x5 40d m-sport space grey
|  Mon Sep 01 2014 6:54am |
| RangeRoyer Member Since: 28 Jul 2014 Location: Worcestershire Posts: 21      | I can see the module in the cargo area under the small flap. This means that the hardware is there but inactive. Will ask the dealer Stratstone why it doesn't work. Thanks... | ||
|  Mon Sep 01 2014 7:21am |
| RangeRoyer Member Since: 28 Jul 2014 Location: Worcestershire Posts: 21      | I say I can see the unit but I'm not sure - please see attached picture.  Is this the right hardware?
|  Mon Sep 01 2014 1:31pm |
| ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698      | It is only clipped in pull it out and it should say what module it is but, I believe most of the modules dab TV etc are just behind that, it means the whole side needs to come off to gain access. ( I don't think that module you are seeing is the bluetooth. ) | ||
|  Mon Sep 01 2014 2:11pm |
| RangeRoyer Member Since: 28 Jul 2014 Location: Worcestershire Posts: 21      | I can see the device by looking through the removable cover in the luggage compartment.  I compared the look of the unit to one being sold on ebay.  This leaves me with the hardware in place but not being recognised by the software.  i.e. when I press PHONE a message saying Phone not installed (or similar).  This means (a) the connector to the hardware unit is not connected (doubtful) (b) the device has been disabled in the software (c) the device is defective.
|  Tue Sep 02 2014 8:26am |
| jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1924    | Presumably pairing is failing?
|  Tue Sep 02 2014 10:27am |
|  Tue Sep 02 2014 11:09am |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | That's not the Blutooth module. It has no MOST optical connector. Bodsys Brake Bible
|  Tue Sep 02 2014 4:34pm |
 Have you checked your VIN on Topix? 2026 P460e Autobiography on order 2022 HSE Dynamic P400e 2017 Discovery 3.0 HSE Silicon Silver Nimbus interior and a few extra toys SOLD 2013 HSE Black, Orkney Grey, Ebony Seats and Ivory Interior SOLD 2006 HSE Plus a few other cars inbetween! | ||
|  Tue Sep 02 2014 4:42pm |
| RangeRoyer Member Since: 28 Jul 2014 Location: Worcestershire Posts: 21      | Checked VIN on TOPix. The vehicle they have is Arctic White - mine is Buckingham Blue! I have asked for validation. Hopefully they will provide a complete options installed list. | ||
|  Tue Sep 02 2014 8:32pm |
| DaveB Member Since: 11 Aug 2014 Posts: 38    | The car will display 'Phone not fitted' until you have paired a phone with it. Pairing can only be done from the phone, not the car so the car will not display anything else regarding bluetooth. Are you saying that after switching on, if you set your phone to search for bluetooth devices the car doesn't appear in the list? It will be identified as LAND ROVER all in upper case. The code is 2121.
|  Wed Sep 03 2014 9:35am |
| RangeRoyer Member Since: 28 Jul 2014 Location: Worcestershire Posts: 21      | When I search for bluetooth devices with my iPhone there is no mention of Land Rover being available. Other bluetooth devices show up but no Land Rover. I suspect that the Bluetooth device is either disabled or disconnected. I can see the bluetooth hardware just behind the Keyless Entry module in my pic. | ||
|  Thu Sep 04 2014 7:09am |
| DaveB Member Since: 11 Aug 2014 Posts: 38    | It does sound as though you have a problem then. The only other suggestions to be absolutely sure is that the ignition must be on, the search on the phone should be done straight away and it can take a minute or two for it to register on your phone. If it still doesn't work with this info then I'd agree you have a problem as it worked first time on my recently acquired 2010 HSE. | ||
|  Thu Sep 04 2014 9:37am |
| Posting Rules
