![]() | Home > General (L494) > 22" and 23" Alloys on a 7 Seater |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
OK, so we know that larger alloys fit on the cars fitted with boot seats...
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
DaveW has assured us that the specific 22 inch wheel/tyre combination on the SVR is fine because it's been tuned as a total package but my experience of 22 inch wheels on the core car is that ride comfort and road noise are seriously compromised so it was only ever going to be 21s for me. 23 is just a step to far and the wheels will scuff if you so much as look at them. Mark
DaveW Member Since: 14 Nov 2013 Location: Warwickshire Posts: 283 ![]() ![]() |
Mark, if you're intending to go off road, then the 21" tyre is the better choice anyway |
Thanks, I daresay we will see comparisons between the two in terms of ride comfort and ultimate performance
Phil, are you intending to go for 21s or 22s? Mark SVR in Estoril Blue ![]() |
Yes you can swap freely between the two sizes as the chassis is signed off dynamically on both tyres. The 22s are a more performance directed tyre and better suited to tarmac use compared to the M&S 21". The 21" M&S tyre has a higher load rating which allows it to cope better with the increased inputs from the chassis, hence these being the only two sizes available on SVR. To answer the earlier question, while I admire some of the work that Overfinch do, certainly more than some other tuning companies, it's worth mentioning that we engineer tyre and wheel assemblies through a rigorous test regime before signing them off so we can't recommend fitting sizes that aren't designed for the car. |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1678 ![]() ![]() ![]() |
22s. But I'm a tart. (ETA: when I talked of the ride at the back, I was referring to that in the boot if you were in a +2 seat as per the OP, not the rear seats of the SVR.) ![]() |
Likewise I was referring to all sizes of JLR wheels across our product range, not just SVR.
Probably worth looking at the thread on wheel spacers and imagining what a load difference the larger wheels might give too. |
