![]() | Home > Technical > Black smoke and loss of power |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
Could be a split in your intercooler pipes maybe? ON THE WAY: BMW F21 M140i
| Higgins Member Since: 19 Aug 2014 Location: Manchester Posts: 4
checked all the pipes and no leaks, i wish it was that simple |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
EGR valve possibly. I believe the EGR functions when at constant revs / when power isn't required. If it's failing to close properly then that would cause issues with power and overfuelling (the black smoke). Have you read the fault codes? 2012 SDV6 - it's missing a couple of cylinders
It doesn't come up with a fault code which is strange, but ive read the actuals on the diagnostics and its showing both EGRs functioning correctly, but ive never had it on when the fault is happening as its difficult to say when its going to happen! it can do it as soon as you pull away or normally it will happen after 10 miles of motorway driving. suppose i should take the diagnostics out and see what the EGRs are doing when the fault is happening ?? |
| Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263
Have you tried a cleaning fuel additive? |
Yeah tried that, I'm just pulling my hair out with it now |
| Dan Stevens Member Since: 19 Aug 2013 Location: Brisbane Posts: 47
i had the same problem.
| All times are GMT |
