![]() | Home > Technical > no power f.....k |
A couple of possibilites spring to mind with this one. Its possible you battery is low on power, or you have a brake light bulb that has blown. I once had the same fault pop up on my dash after a long drive, switched it off, then restarted it and the faults cleared and never returned. |
hunter Member Since: 22 Sep 2013 Location: Nottingham Posts: 318 ![]() ![]() ![]() |
Its probably reacting to you calling it a JEEP................................. Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more |
scott1963 Member Since: 27 Jul 2014 Location: scotland Posts: 18 ![]() ![]() ![]() |
have restarted it a few times same thing.have checked the brake lights everything ok. |
would the break light fault restrict the RPM ??? or battery.i am pritty good at trying to hold my head but this car has f......k my head will never buy another land rover. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4506 ![]() ![]() ![]() |
You need to have the fault codes read, to see why all the lights are coming on
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Try starting the RRS and not the Jeep. It might fix the problem. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
As Disco says, get the fault codes checked out. Also check the brake light switch behind the brake pedal, common failure. |
Might just be worth trying a hard reset - e.g. disconnect battery for at least 30 seconds.
We'll jumped back into my rr two hours later
