Home > Technical > Air con blowing warm
Jonesyscoob
Had it regassed last week as thought it was empty but is still blowing warm when I press auto, I can't hear the motor kick in or any change when button is pressed and I'm sure I used to be able to! Any ideas or advice welcome
Post #432666 Fri Aug 08 2014 5:41pm
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Although you have had the system regassed, was it pressure checked for leakage? probably got a stone chip in the condenser, so your new gas has leaked itself away, the compressor will only work if the system pressure switch detects gas pressure in the system...
Andrew 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
TDV8 HST Stornaway on a 08.. remapped.. now gone and replaced, was a mighty fine car..
4.2 SC First Edition when they first came out, quick car!
Post #432680 Fri Aug 08 2014 9:08pm
Jonesyscoob
Thanks can the same people do that test? Just local garage that did the gas fill
Post #432690 Fri Aug 08 2014 10:33pm
Jonesyscoob
Have had a poke round today there is no gas in the system so must be a leak somewhere as not used since regas, is there any common leak places??
Post #433501 Sun Aug 17 2014 3:04pm
