![]() | Home > General > steering wheel shudder |
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
Track rod ends? Anti roll bar drop links? 2012 SDV6 - it's missing a couple of cylinders
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Hi, you didn't say if the shudder was present before the disc and pad change. It is possible to replace the discs and trap a tiny bit of rust or dirt between the hub and disc so the disc runout is excessive. Everything will seem fine for a few hundred miles perhaps then the shudder starts. If this is the problem then the discs are damaged and will need replacing (check the runout during fitting). If you had the shudder both before and after new discs then it could be a damaged hub causing the excessive runout. Other possibilities are worn components in the steering or suspension so a full check might be worth a try. 2008 MY Java Black TDV8 HSE
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003
Just had the same thing, I changed discs and pads all round, used Brmbo parts. 3000 miles later the shudder came back. Just changed the front discs again under warranty (I hope) and the problem has gone away. Will see what happens after another 3000.. 2008 G4 RRSport TDV8 current
| Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275
Your icon says you have a TdV6 which would not originally have had a Brembo system. If Brembo callipers have been retrofitted they should have anti resonance (vibration) dampers fitted (rectangular chunks of steel bolted inboard to top and bottom of callipers). If Brembos from something else - say a FFRR - have been used, these will be missing as these are specific to the RRS. |
| hunter Member Since: 22 Sep 2013 Location: Nottingham Posts: 318
Are your wheels standard? if not....try a set of spigots....solved my problem..any alloy wheel place will have them and its a cheap fix...... Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more |
The TDV6 did come with Brembo calipers, on models equipped with ARC/Dynamic Response FFRR calipers will not fit an RRS If you have a wobble under braking, then it is more than likely warped discs. What brand of discs did you use? If it is under normal driving, then probably wheel balance |
| scott1963 Member Since: 27 Jul 2014 Location: scotland Posts: 18
the front discs I put on are padgid discs and pads.and were only fitted two months ago.yes I have the brembo callipers fitted and have the two small blocks of metal on top.
Scott...really...all the symptoms are what i had...its easy to try my fix and very cheap compared to going round the houses.... Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more |
hi ok will try the spigots.see if that works. |
Its better to try a £25 fix first than spend hundreds needlessly.............. Gone but not forgotten, 2005 RRS SC first edition, BMW 2010 Z4,TVR Tamora, TVR Cerb, MERC SL 55 AMG, E46 M3, Z4, Jag S type R, Skyline R33 GTR 640 bhp, Evo FQ 400, L322 RR, X5, Lotus Esprit V8 twin turbo, Lotus Elise 135r, Nissan Murano, Honda S2000, 911, Boxster s...and a few more |
| andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155
Had this on my MY12....
| designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338
I get a vibration on the wheel when driving sometimes, not all the time though. Just assumed it was part of the car. Should I be looking for something more? I've it under warranty now, so best find it before it expires. |
Absolutely... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
