Home > Technical > r/rover sport 2.7 diesel no power ?
bigdavy60
2005 Range Rover Sport TDV6 HSE Java Black
hi guys im a newbie member so go please easy , having just recently acquired a 2005 r/r sport 2.7 tubo diesel i was delighted but it has developed a engine sytem fault on dash with no power or kickdown , got my local garage to check out, its giving trouble codes of the following which no disrepect intended they dont seem sure of , any help appreciated guys , thanks in advance
1 PO405 exhaust gas recirculation sensor .a. circuit low
2. P132B turbo/ supercharger boost control -A- performance
3.P138E turbocharger boost control position sensor A - minimum
4. turbo/supercharger boost control solenoid - circuit range/performance
Post #433214 Thu Aug 14 2014 3:02pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
Sounds like your actuator is siezed/sticking spray it with lubricant and work it back and to silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #433223 Thu Aug 14 2014 6:59pm
Disco_Mikey
EGR valve issues in addition. Do you get an "engine system fault" message displayed on the dash on startup?
Post #433243 Thu Aug 14 2014 9:32pm
bigdavy60
ok mate i will see about getting those sprayed with some lube thanks , and yes mike that fault comes on dash at start up does this mean theres an egr fault also then ?
Post #433255 Thu Aug 14 2014 11:35pm
Disco_Mikey
That warning means you have a sticky turbo actuator
Post #433263 Fri Aug 15 2014 6:28am
bigdavy60
cheers mate ill keep you posted on progress
Post #433265 Fri Aug 15 2014 7:46am
bigdavy60
update so far the garage had jeep plugged in and given me a list of trouble codes but not actually done any work to it , not sure if they are scared of it or miffed at me asking on here for advise lol, so have taken it back as dont want it lying around a workshop any longer , im sure ill get someone who cares soon enough lol
Post #433318 Fri Aug 15 2014 8:40pm
BKHK
The problem is that you plugged in the Jeep when you should have plugged in the RRS. No wonder you are not making much progress. Not many people want to work on Jeeps. Laughing Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #433335 Fri Aug 15 2014 11:43pm
bigdavy60
Well I can't say I blame them there mate hehe
Post #433348 Sat Aug 16 2014 10:10am
bigdavy60
replaced the big intercooler pipe on front left hand side of engine as it had started to split although it still has no kick down or power Sad
Post #433395 Sat Aug 16 2014 11:10pm
bigdavy60
are there any independant guys who can quote me a cash price to do this repair ? im in the glasgow area scotland, pm me with info please, cheers
Post #433771 Wed Aug 20 2014 1:42pm
Disco_Mikey is in your bit of the world - see his comment earlier in the thread. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #433777 Wed Aug 20 2014 2:48pm
bigdavy60
hi yes mate i did have some contact with that user name but he never got back to me with any prices , just guessed he must be really busy so just asking about again , thanks for the info ill keep you updated
Post #433779 Wed Aug 20 2014 3:05pm
Disco_Mikey
Shall be down your way on Monday if that's any good for you Thumbs Up
Post #433809 Wed Aug 20 2014 8:18pm
bigdavy60
hi mike can you pm me your hourly labour rates please , pretty sure i have plenty of work on this rrs as ive got a suspension fault now and a few other issues , or if you prefer i can call you with details , cheers
Post #433823 Wed Aug 20 2014 10:48pm
