Home > In Car Electronics > poor radio reception
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Hi has anyone had any similar problem? I can get chanels etc but the reception becomes poor if im not local to a station... Its definately not me being too far away as my van picks the signals up fine.
Where would you suggest i start? Sat nav is fine tho.
Thanks
Post #432273 Sun Aug 03 2014 11:05pm
whippetman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Similar problem just lately...........
Post #432277 Mon Aug 04 2014 7:26am
RRS Daz
Yeah seems weak but also in weak my work car too so not sure it's a sport thing....
Post #432278 Mon Aug 04 2014 8:10am
gogsy1956
I have similar problems in certain areas where I live but it's always related to DAB, all seems fine if I'm on Fm Question 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #432279 Mon Aug 04 2014 8:29am
whippetman
DAB only too.....
Post #432280 Mon Aug 04 2014 8:37am
whippetman
Found this :
Occasionally transmission is affected by planned maintenance work that is carried out at transmitter sites. You may notice that you temporarily lose some stations or the signal strength is reduced (making the signal unreliable) for a while. If you usually pick these stations up without a problem, once the work has been completed ever
Post #432281 Mon Aug 04 2014 8:41am
gogsy1956
I always lose the signal at the exact same place when driving through whitley bay no matter what time of day or night itmay be. I did wonder if the narrow streets and tall buildings where having an effect. 2010 RRS, TDV8
22" overfinch
Post #432282 Mon Aug 04 2014 8:50am
looneyfitter
I don't think mines a maintenance issue. I've actually had this prob for the last 12 month or so. Where is the Aerial on our cars? Just had a though I had my car sprayed 18 month ago. Wondering if it wasn't connected back up properley
Post #432288 Mon Aug 04 2014 10:27am
triplemmm
its built into the rear window. you should be able to see a connection below the window. May be worth checking its connected properly
Post #432299 Mon Aug 04 2014 1:24pm
looneyfitter
You got a pic mate? On the same not my rear elec window demister/heater isn't working either
Post #432312 Mon Aug 04 2014 5:35pm
triplemmm
this is where my AV installer told me my aerial was as the fin on top is for GSM apparently.
There is a connection at the top of each rear window. you need to push the headlining above it up very slightly to see. Its probably hasn't been reconnected. should just plug in if it isn't.
Post #432314 Mon Aug 04 2014 6:01pm
looneyfitter
I'll have a look thanks mate
Post #432316 Mon Aug 04 2014 7:16pm
