![]() | Home > Technical > What's the legal towing limit on rrs? |
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
A bit here;
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9062 ![]() ![]() ![]() |
The vehicle is rated to tow 3500kg with a nose weight of 150kg (in the UK) which was reduced from the earlier nose weight of 250kg.
alexwilson86 Member Since: 27 Jul 2014 Location: leicester Posts: 15 ![]() ![]() |
I'm sure someone told me that it wasn't 3.5t (2.7 rings a bell)
They are all 3.5 tonne towing capacity. The only modern Land Rovers that aren't 3.5 tonne are the Freelander/Evoque. Unless the hybrids are different. 2012 SDV6 - it's missing a couple of cylinders
Thanks to all that have replied. Let the hunt begin 😃 |
SONYBOY Member Since: 22 Dec 2010 Location: East Of England Posts: 70 ![]() ![]() ![]() |
so if im towing something that's 3000 kg and trailer weighs 500 kg =3500 and rrs weighs 3000 = 6500 total is this aloud ??? 2007 COOLRRS |
I think so, yes, because the RRS is less than the GVW and the trailer + load is within the rated towing limit. The two together are less than the gross train weight. 2012 SDV6 - it's missing a couple of cylinders
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 ![]() ![]() |
i had 3.5t on mine the other day and it towed it a dream compared to my transit... |
a) You need the correct licence
