Home > Maintenance & Modifications > diy changing air con condenser,
Page 2 of 3 <123>
Disco_Mikey
Diesel models are 1.5-2 hours, petrol models take longer Thumbs Up
Post #432052 Thu Jul 31 2014 8:32pm
simbad111
I intend to take photos and post them when done. Along with any detail which may help others in future
Post #432060 Thu Jul 31 2014 9:10pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
that sounds more like it mickey
Post #432061 Thu Jul 31 2014 9:15pm
Disco_Mikey
As opposed to this? http://www.disco3.co.uk/forum/topic98740.html
Post #432065 Thu Jul 31 2014 9:37pm
simbad111
Hi guys just to let you know that I have completed the condenser change and all seems well with air con now, the only problems I encountered was rusted torx bolts snapped off drilled out re tapped 8mm and a problem with the parking sensors which is still giving me probs, I disconnected the sensors and connected on refitting the bumper, getting parking aid inactive on dash now,
also anyone know what the 2 light grey connector blocks are behind the head lights with 2 wires going in but nothing coming out the other side, seems like one problem solved another one caused,
Post #432178 Sat Aug 02 2014 6:51pm
cossiedave
At least you got it changed. How long did it take you . I changed bottom ball joint on mine today
Post #432179 Sat Aug 02 2014 7:04pm
simbad111
from start to finish just over 4 hours if I had to do it again I think I could do it in 2 hours, the main prob is getting the seized bolt out bottom of the bumper which all snapped off, had to drill and tap to 8 mm from 6mm, just the parking sensor pro
b now to sort out
Post #432180 Sat Aug 02 2014 7:24pm
simbad111
what are these
Hi can anyone tell me what the grey connector highlighted yellow is please,
Post #432182 Sat Aug 02 2014 8:07pm
Disco_Mikey
TPMS antenna connector Thumbs Up
Post #432186 Sat Aug 02 2014 9:12pm
simbad111
Thanks. Do you know what prob could be with parking sensor. Was all working perfect before removing bumper. I connected all leads
Post #432189 Sat Aug 02 2014 9:19pm
Disco_Mikey
Same happened with my D3 when I had the body off.
All PDC sensors worked fine before. After replacing the engine, and rebuilding, it had 2 faulty sensors. Once replaced, they worked fine again Rolling Eyes
Post #432192 Sat Aug 02 2014 9:45pm
simbad111
hi guys, i bet you all fed up with me now but one final question, can you tell me what this connector is and where should it locate,
Post #432212 Sun Aug 03 2014 9:57am
Isn't that the connector for the (optional) ACC? 2012 SDV6 - it's missing a couple of cylinders
Post #432217 Sun Aug 03 2014 10:17am
Disco_Mikey
It's also there on D3's, which never had the option of ACC.
In addition, the ACC wiring doesn't run that way, it runs along the front crossmember IIRC
Post #432221 Sun Aug 03 2014 10:52am
simbad111
What's ACC. ???
Post #432225 Sun Aug 03 2014 11:02am
Page 2 of 3 <123>
