Home > Maintenance & Modifications > Suspension knocking....again!!!
Disco_Mikey
QMN500240
£85 or so, and half an hour to fit
Post #431525 Thu Jul 24 2014 9:18pm
jack.bauer
jack.bauer wrote:
Disco_Mikey wrote:
Lower steering column Thumbs Up
Visually OK, but when removed from the car, quite often you find play in the sliding joint or U/J Thumbs Up
replaced front ARB now.
noise still there.
LR looking at replac a bush in the lower steering column i believe
So finally resolved
Stratstones replaced the dampers with a later modified kit and also resolved the lower steering column component that had the play. Silence finally 07 TDV8 + BAS map
Post #431916 Wed Jul 30 2014 7:14am
